Aller au contenu principal
Dell Inspiron 15 7579 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 15 7579 Battery Replacement: étape 2, image 2 de 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 15 7579 Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: étape 4, image 1 de 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
10 autres ont terminé cette réparation.
Inaki Madrigal
Membre depuis le 04/23/18
775 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S24-G9, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 membres
6 tutoriels rédigés
2 commentaires
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - Réponse
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 37
Total : 7,108
