Aller au contenu principal
Dell Latitude E7440 Hard Drive Cable Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7440 Hard Drive Cable Replacement, Prepare the laptop: étape 1, image 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: étape 2, image 1 de 3 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: étape 2, image 2 de 3 Dell Latitude E7440 Hard Drive Cable Replacement, Release the battery: étape 2, image 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the battery: étape 3, image 1 de 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: étape 4, image 1 de 2 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the bottom screws: étape 4, image 2 de 2
    • EET owners: Your kit has this bit. No purchase needed.
    • After removing the battery, remove the 2 Phillips #0 screws securing the service panel.
    • Slide the panel off after removing the screws.
  5. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: étape 5, image 1 de 3 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: étape 5, image 2 de 3 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the original HD cable: étape 5, image 3 de 3
    • If your E7440 is missing the caddy or bumpers, these parts can be safely omitted if an SSD is installed. If your unit is complete, remove the 4 screws marked in red. These screws are Phillips #0 if your laptop has them.
    • Pull the tab on the drive cable up to disconnect it from the motherboard.
    • Deroute the hard drive cable from the system.
  6. Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: étape 6, image 1 de 2 Dell Latitude E7440 Hard Drive Cable Replacement, Remove the drive and cable: étape 6, image 2 de 2
    • If you are removing the cable to complete a different repair, do not use force.
    • Remove the drive from the machine, and disconnect the cable.
  7. Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: étape 7, image 1 de 2 Dell Latitude E7440 Hard Drive Cable Replacement, Install the new HD cable: étape 7, image 2 de 2
    • Once the old cable is removed, partially install the replacement cable. Final placement is done with the drive installed.
    • Reinstall the drive into the laptop, and setup the final cable placement.
Nick
Membre depuis le 11/10/09
93 444 Réputation
59 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 698 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 43
Total : 1,109
