Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Precision 3510 Display Assembly Replacement
Ce dont vous avez besoin
    1. Dell Precision 3510 Display Assembly Replacement, Battery: étape 1, image 1 de 2 Dell Precision 3510 Display Assembly Replacement, Battery: étape 1, image 2 de 2
      • Flip the computer over so that you are looking at the bottom.
      • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
      Demander à FixBot
      Ajouter un commentaire
    2. Dell Precision 3510 Display Assembly Replacement: étape 2, image 1 de 1
      • Use the opening tool to carefully pry the base cover from the computer.
      • Remove the base cover from the laptop.
      Demander à FixBot
    3. Dell Precision 3510 Display Assembly Replacement: étape 3, image 1 de 2 Dell Precision 3510 Display Assembly Replacement: étape 3, image 2 de 2
      • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
      Demander à FixBot
    4. Dell Precision 3510 Display Assembly Replacement: étape 4, image 1 de 2 Dell Precision 3510 Display Assembly Replacement: étape 4, image 2 de 2
      • Gently unplug the cable connected to the top of the battery.
      • Remove the battery from the laptop.
      Demander à FixBot
    1. Dell Precision 3510 Display Assembly Replacement, Power Connector Port: étape 5, image 1 de 2 Dell Precision 3510 Display Assembly Replacement, Power Connector Port: étape 5, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the single 3 mm screw from the metal bracket that secures the power port.
      Demander à FixBot
    2. Dell Precision 3510 Display Assembly Replacement: étape 6, image 1 de 2 Dell Precision 3510 Display Assembly Replacement: étape 6, image 2 de 2
      • Lift the metal bracket and gently remove the power connector port.
      • Unplug the power connector port cable from the system board.
      Demander à FixBot
    1. Dell Precision 3510 Display Assembly Replacement, WLAN Card: étape 7, image 1 de 1
      • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
      • Remove the metal bracket from the system board.
      Demander à FixBot
    2. Dell Precision 3510 Display Assembly Replacement: étape 8, image 1 de 1
      • Carefully detach the two cables that are connected to the WLAN card.
      Demander à FixBot
    3. Dell Precision 3510 Display Assembly Replacement: étape 9, image 1 de 1
      • Remove the WLAN card from the system board.
      Demander à FixBot
    1. Dell Precision 3510 Display Assembly Replacement, Display Assembly: étape 10, image 1 de 1
      • Use a Phillips #000 screwdriver to remove the 6.5 mm screws from each display hinge bracket.
      • Remove the two hinge brackets from the computer.
      Demander à FixBot
    2. Dell Precision 3510 Display Assembly Replacement: étape 11, image 1 de 1
      • Carefully unroute the WLAN cables from the system board.
      Demander à FixBot
    3. Dell Precision 3510 Display Assembly Replacement: étape 12, image 1 de 3 Dell Precision 3510 Display Assembly Replacement: étape 12, image 2 de 3 Dell Precision 3510 Display Assembly Replacement: étape 12, image 3 de 3
      • Use a Phillips #000 screwdriver to remove the 3 mm screw from the metal bracket that secures the eDP cable.
      • Gently disconnect the eDP cable from the system board.
      • Unroute the display cable from the system board.
      Demander à FixBot
    4. Dell Precision 3510 Display Assembly Replacement: étape 13, image 1 de 2 Dell Precision 3510 Display Assembly Replacement: étape 13, image 2 de 2
      • Use a Phillips #000 screwdriver to remove the four 4.5 mm screws that secure the display assembly to the system board.
      • Flip the computer face up.
      • Carefully remove the WLAN cables and the display cable from the laptop.
      Demander à FixBot
    5. Dell Precision 3510 Display Assembly Replacement: étape 14, image 1 de 1
      • Detach the display assembly from the system board.
      Demander à FixBot
Makenna Patrick
Membre depuis le 09/24/25
643 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team 46-3, Johansen Fall 2025 Membre de l'équipe Texas Tech, Team 46-3, Johansen Fall 2025
TTU-JOHANSEN-F25S46G3
4 membres
55 tutoriels rédigés
1 commentaire de tutoriel
Great guide & photos! Thank you for putting it up.
Just a few clarifications:
Step 5: two screws secure the power port plate, rather than the single screw mentioned.
Step 8: not "carefully"; REALLY CAREFULLY, or it's new WiFi card time :-D
Step 13 to Step 14: also unscrew the two screws on the rear laptop face which hold the assembly in. They're shown in Step 10, outboard of the hinge covers.
bananaworld - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 73
Total : 307
