Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Precision 5520 Memory Module Replacement
Ce dont vous avez besoin
    1. Dell Precision 5520 Memory Module Replacement, Base Cover: étape 1, image 1 de 2 Dell Precision 5520 Memory Module Replacement, Base Cover: étape 1, image 2 de 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
      • Pry the edges of the base cover and lift it to remove it from the computer.
      • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
      Demander à FixBot
      Ajouter un commentaire
    1. Dell Precision 5520 Memory Module Replacement, Battery: étape 2, image 1 de 1
      • Disconnect the battery cable from the system board [1].
      • Remove the seven M2x4 screws that secure the battery to the computer [2].
      • Lift the battery off the computer [3].
      • Do not apply pressure to the surface of the battery
      • Do not bend
      • Do not use tools of any kind to pry on or against the battery
      • If a battery cannot be removed within the constraints above, please contact Dell technical support
      Demander à FixBot
    1. Dell Precision 5520 Memory Module Replacement, Memory Module: étape 3, image 1 de 1
      • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
      Demander à FixBot
Johnathan Hammond
Membre depuis le 02/28/18
46 185 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
45 membres
12 124 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 32
Total : 1,849
