Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Precision M3800 RAM (Memory) Replacement
Ce dont vous avez besoin
  1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: étape 1, image 1 de 2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    Demander à FixBot
    Ajouter un commentaire
  2. Dell Precision M3800 RAM (Memory) Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    Demander à FixBot
  3. Dell Precision M3800 RAM (Memory) Replacement, Battery: étape 3, image 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
    Demander à FixBot
  4. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): étape 4, image 1 de 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): étape 4, image 2 de 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): étape 4, image 3 de 3
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
    Demander à FixBot
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 724
