Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling Apple IIc Cover
Ce dont vous avez besoin
    1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: étape 1, image 1 de 2 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: étape 1, image 2 de 2
      • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Disassembling Apple IIc Cover: étape 2, image 1 de 2 Disassembling Apple IIc Cover: étape 2, image 2 de 2
      • Release the catch by pushing it in using a plastic opening tool.
      • The catch is off-center, but in line with the middle of the speaker underneath.
      Demander à FixBot
    3. Disassembling Apple IIc Cover: étape 3, image 1 de 2 Disassembling Apple IIc Cover: étape 3, image 2 de 2
      • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
      Demander à FixBot
    4. Disassembling Apple IIc Cover: étape 4, image 1 de 2 Disassembling Apple IIc Cover: étape 4, image 2 de 2
      • Lift the handle straight up to remove.
      Demander à FixBot
10 autres ont terminé cette réparation.
Alexandria Weinberg
Membre depuis le 10/06/11
601 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 membres
72 tutoriels rédigés
3 commentaires de tutoriel
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Réponse Partager
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III - Réponse Partager
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 31
30 derniers jours : 85
Total : 11,499
