Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling Chef's Choice M115 Case
Ce dont vous avez besoin
  1. Disassembling Chef's Choice M115 Case, Case: étape 1, image 1 de 2 Disassembling Chef's Choice M115 Case, Case: étape 1, image 2 de 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
    Demander à FixBot
    Ajouter un commentaire
  2. Disassembling Chef's Choice M115 Case: étape 2, image 1 de 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
    Demander à FixBot
  3. Disassembling Chef's Choice M115 Case: étape 3, image 1 de 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
    Demander à FixBot
  4. Disassembling Chef's Choice M115 Case: étape 4, image 1 de 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
    Demander à FixBot
4 autres ont terminé cette réparation.
Zachary Grounds
Membre depuis le 09/17/15
592 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-3, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 membres
14 tutoriels rédigés
2 commentaires de tutoriel
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Réponse Partager
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 56
Total : 2,426
