Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling the Root Coding Robot
Ce dont vous avez besoin
  1. Disassembling the Root Coding Robot, Removing the bottom screws: étape 1, image 1 de 1
    • The first step in our disassembly is to remove the four bottom Phillips screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Disassembling the Root Coding Robot, Opening up the Root: étape 2, image 1 de 3 Disassembling the Root Coding Robot, Opening up the Root: étape 2, image 2 de 3 Disassembling the Root Coding Robot, Opening up the Root: étape 2, image 3 de 3
    • Once the screws are removed, simply flip the robot face up and lift the top cover. This will expose the Root's motherboard.
    Demander à FixBot
  3. Disassembling the Root Coding Robot, Disconnecting some cables: étape 3, image 1 de 3 Disassembling the Root Coding Robot, Disconnecting some cables: étape 3, image 2 de 3 Disassembling the Root Coding Robot, Disconnecting some cables: étape 3, image 3 de 3
    • Remove the three screws holding the motherboard in place.
    • With a spudger, remove the four cables connected to the motherboard. This will allow us to lift it but there's still a couple of connectors to disconnect.
    • Don't force the motherboard out as the erasing mechanisms and color sensors are still connected to it.
    Demander à FixBot
  4. Disassembling the Root Coding Robot, Removing the motherboard: étape 4, image 1 de 2 Disassembling the Root Coding Robot, Removing the motherboard: étape 4, image 2 de 2
    • Now you can see both connectors still attached to the motherboard, remove them and simply set the motherboard aside.
    Demander à FixBot
  5. Disassembling the Root Coding Robot, Side buttons: étape 5, image 1 de 2 Disassembling the Root Coding Robot, Side buttons: étape 5, image 2 de 2
    • With the motherboard out of the way, we can simply lift the side buttons and remove them.
    Demander à FixBot
  6. Disassembling the Root Coding Robot, Motors: étape 6, image 1 de 3 Disassembling the Root Coding Robot, Motors: étape 6, image 2 de 3 Disassembling the Root Coding Robot, Motors: étape 6, image 3 de 3
    • Without the side buttons we can now easily access the three Phillips screws holding down the motors.
    • Unscrew them and remove the motors.
    Demander à FixBot
  7. Disassembling the Root Coding Robot, Accessing the battery: étape 7, image 1 de 2 Disassembling the Root Coding Robot, Accessing the battery: étape 7, image 2 de 2
    • To access the battery, unscrew the 6 Phillips screws and remove the plastic piece.
    • With motors removed you can now see thge powerful magnets that hold this robot fixed on a whiteboard.
    Demander à FixBot
  8. Disassembling the Root Coding Robot, Battery: étape 8, image 1 de 2 Disassembling the Root Coding Robot, Battery: étape 8, image 2 de 2
    • With access to the battery, you can simply take it out.
    Demander à FixBot
  9. Disassembling the Root Coding Robot, Repositionning some cables: étape 9, image 1 de 2 Disassembling the Root Coding Robot, Repositionning some cables: étape 9, image 2 de 2
    • There's a little cable holder that makes sure the motor cables don't go everywhere, make sure to remove the cables from there.
    Demander à FixBot
  10. Disassembling the Root Coding Robot, Erasing mechanism: étape 10, image 1 de 3 Disassembling the Root Coding Robot, Erasing mechanism: étape 10, image 2 de 3 Disassembling the Root Coding Robot, Erasing mechanism: étape 10, image 3 de 3
    • The cool thing about the Root robot is that it can go on a white board and it can erase stuff. That mechanism is shown here and it can be remove by unscrewing these four screws.
    • Once that's done, remove the erasing mechanism.
    Demander à FixBot
  11. Disassembling the Root Coding Robot, Color sensor board: étape 11, image 1 de 3 Disassembling the Root Coding Robot, Color sensor board: étape 11, image 2 de 3 Disassembling the Root Coding Robot, Color sensor board: étape 11, image 3 de 3
    • To recognize colors, the Root uses a color sensor board at the bottom of the robot. Unscrew the five screws holding the board to the chassis.
    • Remove the board.
    Demander à FixBot
Congratulations, you've made it to the end of the guide, and that concludes the Root Coding robot disassembly.
Alexandre Aires Viegas
Membre depuis le 03/07/25
1 686 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 30
Total : 343
