Aller au contenu principal
Diswoe Switch-01 Trigger Replacement
Ce dont vous avez besoin
  1. Diswoe Switch-01 Trigger Replacement, Battery: étape 1, image 1 de 3 Diswoe Switch-01 Trigger Replacement, Battery: étape 1, image 2 de 3 Diswoe Switch-01 Trigger Replacement, Battery: étape 1, image 3 de 3
    • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
    • Remove the handgrips from the controller.
  2. Diswoe Switch-01 Trigger Replacement: étape 2, image 1 de 3 Diswoe Switch-01 Trigger Replacement: étape 2, image 2 de 3 Diswoe Switch-01 Trigger Replacement: étape 2, image 3 de 3
    • Turn the controller over so the bottom is facing up.
    • Use a Phillips screwdriver to remove the five screws from the back case.
  3. Diswoe Switch-01 Trigger Replacement: étape 3, image 1 de 3 Diswoe Switch-01 Trigger Replacement: étape 3, image 2 de 3 Diswoe Switch-01 Trigger Replacement: étape 3, image 3 de 3
    • Use both hands to carefully remove the back cover.
    • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
    • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
  4. Diswoe Switch-01 Trigger Replacement: étape 4, image 1 de 3 Diswoe Switch-01 Trigger Replacement: étape 4, image 2 de 3 Diswoe Switch-01 Trigger Replacement: étape 4, image 3 de 3
    • Push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
  5. Diswoe Switch-01 Trigger Replacement: étape 5, image 1 de 2 Diswoe Switch-01 Trigger Replacement: étape 5, image 2 de 2
    • Remove the battery from the main circuit board.
    • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
  6. Diswoe Switch-01 Trigger Replacement, Trigger: étape 6, image 1 de 1
    • Right under where the triggers were, you should see some small loose rectangular pieces of circuit board. These are the sensors that register the clicks of the triggers. Lightly blow on them and dust them gently in order to clean them. If they move out of place, simply move them back into place.
    • If needed, you can also remove the trigger buttons from the case, you can replace these with newer ones if they are too rundown for your liking or if they become damaged.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Edgar Medina
Membre depuis le 09/09/24
153 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-3, Kershman Fall 2024 Membre de l'équipe CSU Los Angeles, Team 2-3, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G3
5 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 36
