Introduction
Follow this guide to replace the midframe in your DualShock 4 model CUH-ZCT1U controller.
The midframe includes the motherboard, vibration motors, and button circuit membrane.
Ce dont vous avez besoin
Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
Outil utilisé dans cette étape :Microfiber Cleaning Cloths$3.99
Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
Use an opening pick to pry each corner of the L1 button from the front case.
Remove the button.
Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
Slide your pick toward the handle and pry up to release the first clip.
Repeat this procedure on the other side of the controller to release the second clip.
Outil utilisé dans cette étape :Tweezers$4.99
Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
Grab and remove the reset button extension from its recess in the battery bracket.
Locate the two clips securing the battery bracket to the motherboard.
Insert the point of your spudger into the opening behind the right bracket clip.
Depress the clip to disengage it from the motherboard.
Lift up the right edge of the battery bracket.
Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
Use tweezers or your fingers to disconnect the cable using its blue pull tab.
Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
Grab the midframe by its plastic protrusions or the vibration motors and remove it.
