Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dyson DC14 Power Switch Replacement
Ce dont vous avez besoin
    1. Dyson DC14 Power Switch Replacement, Power Switch: étape 1, image 1 de 2 Dyson DC14 Power Switch Replacement, Power Switch: étape 1, image 2 de 2
      • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
      • Remove the canister from the vacuum.
      • Disconnect the telescopic vacuum wand.
      • Remove the two T15 Torx screws securing the switch cover to the vacuum.
      Demander à FixBot
      Ajouter un commentaire
    2. Dyson DC14 Power Switch Replacement: étape 2, image 1 de 2 Dyson DC14 Power Switch Replacement: étape 2, image 2 de 2
      • Push outward on the two plastic clips that secure the switch cover to the vacuum.
      Demander à FixBot
    3. Dyson DC14 Power Switch Replacement: étape 3, image 1 de 1
      • Remove the switch cover from the vacuum.
      • The purple switch button may separate from the rest of the switch cover.
      Demander à FixBot
    4. Dyson DC14 Power Switch Replacement: étape 4, image 1 de 1
      • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
      • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
      • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
      Demander à FixBot
19 autres ont terminé cette réparation.
Zachary
Membre depuis le 10/06/12
318 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-22, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 membres
14 tutoriels rédigés
10 commentaires de tutoriel
Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!
Tim Swift - Réponse Partager
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Robert Williams - Réponse Partager
I replaced my power switch. Easy! $15 part!
brdurham - Réponse Partager
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Queenie - Réponse Partager
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
Tariq Rafique - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 57
Total : 39,543
