Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Eclipse 180BL Battery Replacement
Ce dont vous avez besoin
  1. Eclipse 180BL Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
    Demander à FixBot
    Ajouter un commentaire
  2. Eclipse 180BL Battery Replacement: étape 2, image 1 de 2 Eclipse 180BL Battery Replacement: étape 2, image 2 de 2
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
    Demander à FixBot
  3. Eclipse 180BL Battery Replacement: étape 3, image 1 de 3 Eclipse 180BL Battery Replacement: étape 3, image 2 de 3 Eclipse 180BL Battery Replacement: étape 3, image 3 de 3
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
    Demander à FixBot
  4. Eclipse 180BL Battery Replacement: étape 4, image 1 de 1
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
    Demander à FixBot
3 autres ont terminé cette réparation.
Thomas Schwarz
Membre depuis le 09/07/15
499 Réputation
3 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 59
Total : 2,206
