Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Eightarc Fusion Button Replacement
Ce dont vous avez besoin
  1. Eightarc Fusion Button Replacement, Buttons: étape 1, image 1 de 1
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Demander à FixBot
    Ajouter un commentaire
  2. Eightarc Fusion Button Replacement: étape 2, image 1 de 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Demander à FixBot
  3. Eightarc Fusion Button Replacement: étape 3, image 1 de 1
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    Demander à FixBot
  4. Eightarc Fusion Button Replacement: étape 4, image 1 de 2 Eightarc Fusion Button Replacement: étape 4, image 2 de 2
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    Demander à FixBot
  5. Eightarc Fusion Button Replacement: étape 5, image 1 de 2 Eightarc Fusion Button Replacement: étape 5, image 2 de 2
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    Demander à FixBot
Austin
Membre depuis le 01/28/15
245 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-35, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 30
Total : 1,134
