Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Eightarc Fusion USB Cable Replacement
Ce dont vous avez besoin
  1. Eightarc Fusion USB Cable Replacement, USB Cable: étape 1, image 1 de 2 Eightarc Fusion USB Cable Replacement, USB Cable: étape 1, image 2 de 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Demander à FixBot
    Ajouter un commentaire
  2. Eightarc Fusion USB Cable Replacement: étape 2, image 1 de 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Demander à FixBot
  3. Eightarc Fusion USB Cable Replacement: étape 3, image 1 de 1
    • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
    • Be sure to be gentle and not snap the plastic flap in half.
    Demander à FixBot
  4. Eightarc Fusion USB Cable Replacement: étape 4, image 1 de 1
    • Slide USB cable up from the plastic barrier casing.
    Demander à FixBot
  5. Eightarc Fusion USB Cable Replacement: étape 5, image 1 de 3 Eightarc Fusion USB Cable Replacement: étape 5, image 2 de 3 Eightarc Fusion USB Cable Replacement: étape 5, image 3 de 3
    • The USB cord is connected to the logic board by a plastic plug with five wires.
    • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
    • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
    • Remove USB cable from device.
    Demander à FixBot
Dana
Membre depuis le 02/01/15
141 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-35, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Where do I get the USB wire?
desmond.bouey1 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 39
Total : 1,238
