Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Element GC-1020 Display Replacement
Ce dont vous avez besoin
  1. Element GC-1020 Display Replacement, Back Cover Replacement Guide: étape 1, image 1 de 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
    Demander à FixBot
    Ajouter un commentaire
  2. Element GC-1020 Display Replacement: étape 2, image 1 de 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
    Demander à FixBot
  3. Element GC-1020 Display Replacement, Display: étape 3, image 1 de 1
    • Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
    Demander à FixBot
  4. Element GC-1020 Display Replacement: étape 4, image 1 de 2 Element GC-1020 Display Replacement: étape 4, image 2 de 2
    • Carefully bend the plastic frame to remove the motherboard.
    • Upon doing this make sure your power button on the bottom left side stays attached to the outer frame because it will loosen as the motherboard is moved upwards.
    Demander à FixBot
  5. Element GC-1020 Display Replacement: étape 5, image 1 de 1
    • The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
    Demander à FixBot
  6. Element GC-1020 Display Replacement: étape 6, image 1 de 3 Element GC-1020 Display Replacement: étape 6, image 2 de 3 Element GC-1020 Display Replacement: étape 6, image 3 de 3
    • Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
    Demander à FixBot
2 autres ont terminé cette réparation.
Lashaun Noel
Membre depuis le 09/25/15
591 Réputation
5 tutoriels rédigés
Équipe
University of Tampa, Team 1-4, Whiteside Fall 2015 Membre de l'équipe University of Tampa, Team 1-4, Whiteside Fall 2015
UT-WHITESIDE-F15S1G4
4 membres
10 tutoriels rédigés
1 commentaire de tutoriel
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
Nisha Najihah - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 27
Total : 670
