Introduction
In the case that your solar panel is damaged or malfunctioning, you may need to swap it out. But no need to worry, it's actually a very straight forward fix that just involves 6 screws and 4 plugs!
Ce dont vous avez besoin
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
The solar panel is connected to the motherboard through a simple socket, just pull up to unplug.
