Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ExoPC Slate CPU Fan Replacement
Ce dont vous avez besoin
    1. ExoPC Slate CPU Fan Replacement, Back Cover and Shield: étape 1, image 1 de 2 ExoPC Slate CPU Fan Replacement, Back Cover and Shield: étape 1, image 2 de 2
      • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
      Demander à FixBot
      Ajouter un commentaire
    2. ExoPC Slate CPU Fan Replacement: étape 2, image 1 de 2 ExoPC Slate CPU Fan Replacement: étape 2, image 2 de 2
      • Using the 00 Phillips screwdriver remove the two screws in the corners.
      • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
      • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
      Demander à FixBot
    3. ExoPC Slate CPU Fan Replacement: étape 3, image 1 de 3 ExoPC Slate CPU Fan Replacement: étape 3, image 2 de 3 ExoPC Slate CPU Fan Replacement: étape 3, image 3 de 3
      • Remove the tape covering the metal shield.
      • Remove the 12 screws using the Phillips #00 screwdriver.
      • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
      Demander à FixBot
    1. ExoPC Slate CPU Fan Replacement, CPU Fan: étape 4, image 1 de 2 ExoPC Slate CPU Fan Replacement, CPU Fan: étape 4, image 2 de 2
      • Remove the yellow tape securing the wires to the PCB board as well as the silver/grey tape.
      • Unscrew the six Phillips #00 screws.
      Demander à FixBot
    2. ExoPC Slate CPU Fan Replacement: étape 5, image 1 de 2 ExoPC Slate CPU Fan Replacement: étape 5, image 2 de 2
      Outil utilisé dans cette étape :
      • Using tweezers, disconnect the connector in the top left.
      • Pull the fan heat sink away from the PC.
      • Remove the fan from the copper heat sink with the tweezers by releasing the metal clips.
      • Apply a sparing amount of thermal paste to each chip.
      • Attach the new or cleaned fan to the heat sink using the metal clips. Line up the heat sink with the screw holes and press down firmly to spread out the thermal paste.
      Demander à FixBot
Jonathon Cronin
Membre depuis le 10/29/18
337 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G1, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G1, Peak Fall 2018
UMASSD-PEAK-F18S2G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 49
Total : 641
