Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Farberware FSTO100 Indicator Light Replacement
Ce dont vous avez besoin
    1. Farberware FSTO100 Indicator Light Replacement, Indicator Light: étape 1, image 1 de 1
      • Make sure toaster is unplugged.
      • Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
      Demander à FixBot
      Ajouter un commentaire
    2. Farberware FSTO100 Indicator Light Replacement: étape 2, image 1 de 1
      • On the left hand side, unscrew the middle screw.
      Demander à FixBot
    3. Farberware FSTO100 Indicator Light Replacement: étape 3, image 1 de 1
      • Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
      Demander à FixBot
    4. Farberware FSTO100 Indicator Light Replacement: étape 4, image 1 de 1
      • Pull the black wires to remove the indicator light from the red tube.
      Demander à FixBot
    5. Farberware FSTO100 Indicator Light Replacement: étape 5, image 1 de 2 Farberware FSTO100 Indicator Light Replacement: étape 5, image 2 de 2
      • Use scissors to cut open cord sheathing and peel back.
      Demander à FixBot
    6. Farberware FSTO100 Indicator Light Replacement: étape 6, image 1 de 1
      • Use the wire-cutters to remove the light bulb.
      Demander à FixBot
    7. Farberware FSTO100 Indicator Light Replacement: étape 7, image 1 de 2 Farberware FSTO100 Indicator Light Replacement: étape 7, image 2 de 2
      • Solder the replacement light bulb back onto its original position.
      Demander à FixBot
    8. Farberware FSTO100 Indicator Light Replacement: étape 8, image 1 de 1
      • Use electrical tape to reseal the sheathing.
      Demander à FixBot
    9. Farberware FSTO100 Indicator Light Replacement: étape 9, image 1 de 1
      • Reinsert the indicator light back into the red tube.
      Demander à FixBot
    10. Farberware FSTO100 Indicator Light Replacement: étape 10, image 1 de 1
      Demander à FixBot
    11. Farberware FSTO100 Indicator Light Replacement: étape 11, image 1 de 1
      • On the left hand side, screw the middle screw back in.
      Demander à FixBot
Tony Wang
Membre depuis le 10/05/12
112 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-35, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-35, Regan Fall 2012
CPSU-REGAN-F12S6G35
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 26
Total : 1,216
