Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Fender Starcaster Bridge Replacement
Ce dont vous avez besoin
  1. Fender Starcaster Bridge Replacement, Loosen the Strings: étape 1, image 1 de 3 Fender Starcaster Bridge Replacement, Loosen the Strings: étape 1, image 2 de 3 Fender Starcaster Bridge Replacement, Loosen the Strings: étape 1, image 3 de 3
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
    Demander à FixBot
    Ajouter un commentaire
  2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 1 de 2 Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 2 de 2
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
    Demander à FixBot
  3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: étape 3, image 1 de 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: étape 3, image 2 de 3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: étape 3, image 3 de 3
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    Demander à FixBot
  4. Fender Starcaster Bridge Replacement, Bridge: étape 4, image 1 de 2 Fender Starcaster Bridge Replacement, Bridge: étape 4, image 2 de 2
    • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
    Demander à FixBot
  5. Fender Starcaster Bridge Replacement: étape 5, image 1 de 3 Fender Starcaster Bridge Replacement: étape 5, image 2 de 3 Fender Starcaster Bridge Replacement: étape 5, image 3 de 3
    • To remove the springs from the bridge, grip the end with pliers and pull up.
    • It is safe to use the body of the guitar for leverage.
    Demander à FixBot
  6. Fender Starcaster Bridge Replacement: étape 6, image 1 de 3 Fender Starcaster Bridge Replacement: étape 6, image 2 de 3 Fender Starcaster Bridge Replacement: étape 6, image 3 de 3
    • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
    Demander à FixBot
  7. Fender Starcaster Bridge Replacement: étape 7, image 1 de 3 Fender Starcaster Bridge Replacement: étape 7, image 2 de 3 Fender Starcaster Bridge Replacement: étape 7, image 3 de 3
    • Remove the screws from the front of the bridge.
    • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
    Demander à FixBot
  8. Fender Starcaster Bridge Replacement: étape 8, image 1 de 1
    • With all six screws removed, lift up on the bridge to remove it from the body.
    Demander à FixBot
2 autres ont terminé cette réparation.
Christopher Hartigan
Membre depuis le 09/10/14
164 Réputation
5 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-3, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 47
Total : 3,092
