Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Fender Starcaster String Replacement
Ce dont vous avez besoin
    1. Fender Starcaster String Replacement, Loosen the Strings: étape 1, image 1 de 3 Fender Starcaster String Replacement, Loosen the Strings: étape 1, image 2 de 3 Fender Starcaster String Replacement, Loosen the Strings: étape 1, image 3 de 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Demander à FixBot
      Ajouter un commentaire
    2. Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 1 de 2 Fender Starcaster String Replacement, Remove the Strings from the Tuning Pegs: étape 2, image 2 de 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Demander à FixBot
    3. Fender Starcaster String Replacement, Remove the Strings from the Bridge: étape 3, image 1 de 3 Fender Starcaster String Replacement, Remove the Strings from the Bridge: étape 3, image 2 de 3 Fender Starcaster String Replacement, Remove the Strings from the Bridge: étape 3, image 3 de 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Demander à FixBot
    1. Fender Starcaster String Replacement, String: étape 4, image 1 de 3 Fender Starcaster String Replacement, String: étape 4, image 2 de 3 Fender Starcaster String Replacement, String: étape 4, image 3 de 3
      • Take any one of the new strings and slide it through the appropriate bridge hole.
      • The replacement strings used on this guitar were "Regular Slinky" by Ernie Ball, which is a 10 gauge string set.
      • 6th String: E - 46 Gauge
      • 5th String: A - 36 Gauge
      • 4th String: D - 26 Gauge
      • 3rd String: G - 17 Gauge
      • 2nd String: B - 13 Gauge
      • 1st String: E - 10 Guage
      Demander à FixBot
    2. Fender Starcaster String Replacement: étape 5, image 1 de 3 Fender Starcaster String Replacement: étape 5, image 2 de 3 Fender Starcaster String Replacement: étape 5, image 3 de 3
      • Lay the string parallel to the guitar's neck and directly over the appropriate tuning peg.
      • Measure a "three finger's length" (about 1.5") on the string passed the tuning peg.
      • Make a sharp bend in the string at where you measured 1.5" passed the tuning peg.
      • Turn the tuning peg until the string hole faces perpendicular to the guitar's neck.
      • Feed the bent string into the tuning peg until the bend meets the tuning post.
      Demander à FixBot
    3. Fender Starcaster String Replacement: étape 6, image 1 de 3 Fender Starcaster String Replacement: étape 6, image 2 de 3 Fender Starcaster String Replacement: étape 6, image 3 de 3
      • Make another sharp bend in the string on the outside of the tuning post.
      • Turn the tuning key counter clockwise while applying light pressure to the string on the inside of the post.
      • Wrapping the string around the post will help the string stay in-tune longer.
      • If the wraps of the string around the post start to roll over the top of the post, hold them down while still turning the post.
      • Continue turning the post until at least 2 full wraps of the string have been made around the post.
      Demander à FixBot
    4. Fender Starcaster String Replacement: étape 7, image 1 de 2 Fender Starcaster String Replacement: étape 7, image 2 de 2
      • Snip the excess string off from the post with a wire cutter (leaving at least half an inch of string left).
      Demander à FixBot
    5. Fender Starcaster String Replacement: étape 8, image 1 de 3 Fender Starcaster String Replacement: étape 8, image 2 de 3 Fender Starcaster String Replacement: étape 8, image 3 de 3
      • Continue installing strings using the the same method described in the last few steps.
      • The last four strings (the D, G, B, and E strings), must be guided underneath the two "string trees" in the center of the headstock.
      • String Tree for the D and G strings
      • String Tree for the B and E strings
      • Tune the strings to your desired pitch and your guitar is ready to play!
      Demander à FixBot
3 autres ont terminé cette réparation.
Jasper Fleischhauer
Membre depuis le 10/20/14
37 755 Réputation
2 tutoriels rédigés
1 commentaire de tutoriel
Good guide very helpful.
Neo kramer - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 63
Total : 7,037
