Aller au contenu principal
Pour réparer ensemble - Je crée un compte
GameSir G7 SE Joystick Module Replacement
Ce dont vous avez besoin
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: étape 1, image 1 de 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
    Demander à FixBot
    Ajouter un commentaire
  2. GameSir G7 SE Joystick Module Replacement: étape 2, image 1 de 2 GameSir G7 SE Joystick Module Replacement: étape 2, image 2 de 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
    Demander à FixBot
  3. GameSir G7 SE Joystick Module Replacement: étape 3, image 1 de 2 GameSir G7 SE Joystick Module Replacement: étape 3, image 2 de 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
    Demander à FixBot
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: étape 4, image 1 de 1
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
    Demander à FixBot
  5. GameSir G7 SE Joystick Module Replacement: étape 5, image 1 de 1
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
    Demander à FixBot
  6. GameSir G7 SE Joystick Module Replacement: étape 6, image 1 de 1
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
    Demander à FixBot
5 autres ont terminé cette réparation.
AJ Saks
Membre depuis le 01/23/24
258 Réputation
1 tutoriel rédigé
Équipe
4 commentaires de tutoriel
Where to get the replacement parts?
Isaiah Hackworth - Réponse Partager
Where do you get the replacement parts from?
michaeljhs - Réponse Partager
Guida inutile senza ricambio
Matteo Andreani - Réponse Partager
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - Réponse Partager
Nombre de vues :
Dernières 24 heures : 38
7 derniers jours : 165
30 derniers jours : 805
Total : 13,297
