Introduction
This guide will walk you through the process of replacing a button on the Forerunner 405.
Ce dont vous avez besoin
Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
Lift the motherboard out of the watch.
Outil utilisé dans cette étape :Tweezers$4.99
Push button in and pinch silver clip with tweezers.
Pull silver clip off the pin it is on.
Pull out button and replace.
2 commentaires de tutoriel
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
