Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Garmin Rino 700 Screen Replacement
Ce dont vous avez besoin
  1. Garmin Rino 700 Screen Replacement, Battery Disconnect: étape 1, image 1 de 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
    Demander à FixBot
    Ajouter un commentaire
  2. Garmin Rino 700 Screen Replacement: étape 2, image 1 de 2 Garmin Rino 700 Screen Replacement: étape 2, image 2 de 2
    • Remove the battery cover and set it to the side.
    Demander à FixBot
  3. Garmin Rino 700 Screen Replacement: étape 3, image 1 de 2 Garmin Rino 700 Screen Replacement: étape 3, image 2 de 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
    Demander à FixBot
  4. Garmin Rino 700 Screen Replacement, Motherboard: étape 4, image 1 de 2 Garmin Rino 700 Screen Replacement, Motherboard: étape 4, image 2 de 2
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
    Demander à FixBot
  5. Garmin Rino 700 Screen Replacement: étape 5, image 1 de 3 Garmin Rino 700 Screen Replacement: étape 5, image 2 de 3 Garmin Rino 700 Screen Replacement: étape 5, image 3 de 3
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
    Demander à FixBot
  6. Garmin Rino 700 Screen Replacement, Screen: étape 6, image 1 de 3 Garmin Rino 700 Screen Replacement, Screen: étape 6, image 2 de 3 Garmin Rino 700 Screen Replacement, Screen: étape 6, image 3 de 3
    • Carefully detach the screen at the bottom connections using your hands to reveal the ribbon connection.
    • For a guide on disconnecting and reconnecting the Zero Insertion Force (ZIF) connectors, please visit this guide.
    Demander à FixBot
Abigail Dugan
Membre depuis le 09/28/21
512 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 5-5, Hunter Fall 2021 Membre de l'équipe Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 675
