Aller au contenu principal
Garmin Vívoactive 4 Screen Replacement
Ce dont vous avez besoin
  1. Garmin Vívoactive 4 Screen Replacement, Watch Band: étape 1, image 1 de 1
    • Flip the watch on its back to reveal the watch band connection pins.
  2. Garmin Vívoactive 4 Screen Replacement, Remove Bands: étape 2, image 1 de 3 Garmin Vívoactive 4 Screen Replacement, Remove Bands: étape 2, image 2 de 3 Garmin Vívoactive 4 Screen Replacement, Remove Bands: étape 2, image 3 de 3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
  3. Garmin Vívoactive 4 Screen Replacement: étape 3, image 1 de 1
    • With both straps removed, a new replacement watch band may be inserted.
  4. Garmin Vívoactive 4 Screen Replacement, Screen: étape 4, image 1 de 1
    • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
    • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
  5. Garmin Vívoactive 4 Screen Replacement: étape 5, image 1 de 2 Garmin Vívoactive 4 Screen Replacement: étape 5, image 2 de 2
    • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
    • Pry the screen off the device.
    • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
    • Work quickly so the adhesive doesn’t cool too much.
  6. Garmin Vívoactive 4 Screen Replacement: étape 6, image 1 de 3 Garmin Vívoactive 4 Screen Replacement: étape 6, image 2 de 3 Garmin Vívoactive 4 Screen Replacement: étape 6, image 3 de 3
    • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
  7. Garmin Vívoactive 4 Screen Replacement: étape 7, image 1 de 1
    • Remove the screen.
Jacob Byron
Membre depuis le 11/01/23
201 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Petersen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 1-3, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 41
30 derniers jours : 179
Total : 973
