Aller au contenu principal
Garmin Vivoactive Battery Replacement
Ce dont vous avez besoin
  1. Garmin Vivoactive Battery Replacement, Wristband: étape 1, image 1 de 1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
  2. Garmin Vivoactive Battery Replacement: étape 2, image 1 de 2 Garmin Vivoactive Battery Replacement: étape 2, image 2 de 2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
  3. Garmin Vivoactive Battery Replacement, Display Unit: étape 3, image 1 de 1
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
  4. Garmin Vivoactive Battery Replacement: étape 4, image 1 de 2 Garmin Vivoactive Battery Replacement: étape 4, image 2 de 2
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
  5. Garmin Vivoactive Battery Replacement: étape 5, image 1 de 1
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
  6. Garmin Vivoactive Battery Replacement: étape 6, image 1 de 1
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
  7. Garmin Vivoactive Battery Replacement: étape 7, image 1 de 1
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
  8. Garmin Vivoactive Battery Replacement: étape 8, image 1 de 1
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
  9. Garmin Vivoactive Battery Replacement, Battery: étape 9, image 1 de 2 Garmin Vivoactive Battery Replacement, Battery: étape 9, image 2 de 2
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
  10. Garmin Vivoactive Battery Replacement: étape 10, image 1 de 2 Garmin Vivoactive Battery Replacement: étape 10, image 2 de 2
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
  11. Garmin Vivoactive Battery Replacement: étape 11, image 1 de 3 Garmin Vivoactive Battery Replacement: étape 11, image 2 de 3 Garmin Vivoactive Battery Replacement: étape 11, image 3 de 3
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
16 autres ont terminé cette réparation.
Michael Clark
Membre depuis le 10/01/15
658 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-21, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 membres
17 tutoriels rédigés
28 commentaires
But battery buy where?
sanborn - Réponse
where to buy battery?
Whitney Oliver - Réponse
I have the Same question... where can i buy the replacement?
Roli - Réponse
I've tried everywhere to find a battery for my vivoactive, with no luck. Where should I look to find a battery? HELP!
David -
Battery is a 3.7 V, 150 mAh Li-Polymer type.
Gary K - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 116
30 derniers jours : 555
Total : 106,019
