Aller au contenu principal
Pour réparer ensemble - Je crée un compte
General Electric Create Jason Wu Casing Disassembly
Ce dont vous avez besoin
    1. General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: étape 1, image 1 de 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: étape 1, image 2 de 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: étape 1, image 3 de 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Demander à FixBot
      Ajouter un commentaire
    2. General Electric Create Jason Wu Casing Disassembly: étape 2, image 1 de 2 General Electric Create Jason Wu Casing Disassembly: étape 2, image 2 de 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Demander à FixBot
    3. General Electric Create Jason Wu Casing Disassembly: étape 3, image 1 de 3 General Electric Create Jason Wu Casing Disassembly: étape 3, image 2 de 3 General Electric Create Jason Wu Casing Disassembly: étape 3, image 3 de 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Demander à FixBot
    4. General Electric Create Jason Wu Casing Disassembly: étape 4, image 1 de 3 General Electric Create Jason Wu Casing Disassembly: étape 4, image 2 de 3 General Electric Create Jason Wu Casing Disassembly: étape 4, image 3 de 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Demander à FixBot
2 autres ont terminé cette réparation.
Kylan Hennessy
Membre depuis le 01/23/17
573 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 565
