Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Giant Reign 2 Headset Replacement
Ce dont vous avez besoin
  1. Giant Reign 2 Headset Replacement, Hex Screws: étape 1, image 1 de 1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    Demander à FixBot
    Ajouter un commentaire
  2. Giant Reign 2 Headset Replacement, Axle Screw: étape 2, image 1 de 2 Giant Reign 2 Headset Replacement, Axle Screw: étape 2, image 2 de 2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
    Demander à FixBot
  3. Giant Reign 2 Headset Replacement: étape 3, image 1 de 1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    Demander à FixBot
  4. Giant Reign 2 Headset Replacement, Front Wheel: étape 4, image 1 de 1
    • Pull the wheel from the fork.
    Demander à FixBot
  5. Giant Reign 2 Headset Replacement, Headset: étape 5, image 1 de 2 Giant Reign 2 Headset Replacement, Headset: étape 5, image 2 de 2
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
    Demander à FixBot
  6. Giant Reign 2 Headset Replacement: étape 6, image 1 de 3 Giant Reign 2 Headset Replacement: étape 6, image 2 de 3 Giant Reign 2 Headset Replacement: étape 6, image 3 de 3
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
    Demander à FixBot
  7. Giant Reign 2 Headset Replacement: étape 7, image 1 de 3 Giant Reign 2 Headset Replacement: étape 7, image 2 de 3 Giant Reign 2 Headset Replacement: étape 7, image 3 de 3
    • Slide off the spacers.
    • Lift off the seal.
    Demander à FixBot
  8. Giant Reign 2 Headset Replacement: étape 8, image 1 de 1
    • Slide the fork out of the casing.
    Demander à FixBot
  9. Giant Reign 2 Headset Replacement: étape 9, image 1 de 1
    • Using your fingers, pry the bearings from the top and bottom of the headset.
    Demander à FixBot
  10. Giant Reign 2 Headset Replacement: étape 10, image 1 de 1
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
    Demander à FixBot
  11. Giant Reign 2 Headset Replacement: étape 11, image 1 de 2 Giant Reign 2 Headset Replacement: étape 11, image 2 de 2
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
    Demander à FixBot
Sterling Grande
Membre depuis le 10/08/12
148 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 39
Total : 4,654
