Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Home Sound Driver Replacement
Ce dont vous avez besoin
  1. Google Home Sound Driver Replacement, Interconnect Cable: étape 1, image 1 de 3 Google Home Sound Driver Replacement, Interconnect Cable: étape 1, image 2 de 3 Google Home Sound Driver Replacement, Interconnect Cable: étape 1, image 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Home Sound Driver Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    • Carefully remove the interconnect cable using a pair of tweezers.
    Demander à FixBot
  3. Google Home Sound Driver Replacement, Mute Button Switch: étape 3, image 1 de 2 Google Home Sound Driver Replacement, Mute Button Switch: étape 3, image 2 de 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    Demander à FixBot
  4. Google Home Sound Driver Replacement: étape 4, image 1 de 2 Google Home Sound Driver Replacement: étape 4, image 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
    Demander à FixBot
  5. Google Home Sound Driver Replacement, Motherboard: étape 5, image 1 de 2 Google Home Sound Driver Replacement, Motherboard: étape 5, image 2 de 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
    Demander à FixBot
  6. Google Home Sound Driver Replacement: étape 6, image 1 de 2 Google Home Sound Driver Replacement: étape 6, image 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
    Demander à FixBot
  7. Google Home Sound Driver Replacement, Sound Driver: étape 7, image 1 de 2 Google Home Sound Driver Replacement, Sound Driver: étape 7, image 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
    Demander à FixBot
  8. Google Home Sound Driver Replacement: étape 8, image 1 de 2 Google Home Sound Driver Replacement: étape 8, image 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
    Demander à FixBot
  9. Google Home Sound Driver Replacement: étape 9, image 1 de 2 Google Home Sound Driver Replacement: étape 9, image 2 de 2
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
    Demander à FixBot
6 autres ont terminé cette réparation.
Gabe Hyun
Membre depuis le 04/17/18
847 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 membres
10 tutoriels rédigés
4 commentaires de tutoriel
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - Réponse Partager
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - Réponse Partager
Looking for replacement speaker, where do I find?
Corey Anderson - Réponse Partager
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 60
Total : 3,045
