Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 2 Display Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Google Pixel 2 Display Replacement, Display: étape 1, image 1 de 2 Google Pixel 2 Display Replacement, Display: étape 1, image 2 de 2
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixel 2 Display Replacement: étape 2, image 1 de 3 Google Pixel 2 Display Replacement: étape 2, image 2 de 3 Google Pixel 2 Display Replacement: étape 2, image 3 de 3
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
    Demander à FixBot
  3. Google Pixel 2 Display Replacement: étape 3, image 1 de 3 Google Pixel 2 Display Replacement: étape 3, image 2 de 3 Google Pixel 2 Display Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
    Demander à FixBot
  4. Google Pixel 2 Display Replacement: étape 4, image 1 de 1
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
    Demander à FixBot
Monica Andres
Membre depuis le 01/24/18
289 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G5, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 membres
23 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 31
Total : 1,357
