Aller au contenu principal
Google Pixel 3 Back Cover Adhesive Installation
Ce dont vous avez besoin
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: étape 1, image 1 de 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: étape 1, image 2 de 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: étape 1, image 3 de 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: étape 2, image 1 de 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: étape 2, image 2 de 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: étape 2, image 3 de 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: étape 3, image 1 de 1
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: étape 4, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: étape 4, image 2 de 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: étape 5, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: étape 5, image 2 de 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: étape 6, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: étape 6, image 2 de 2
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: étape 7, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
  8. Google Pixel 3 Back Cover Adhesive Installation: étape 8, image 1 de 3 Google Pixel 3 Back Cover Adhesive Installation: étape 8, image 2 de 3 Google Pixel 3 Back Cover Adhesive Installation: étape 8, image 3 de 3
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
  9. Google Pixel 3 Back Cover Adhesive Installation: étape 9, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation: étape 9, image 2 de 2
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: étape 10, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: étape 10, image 2 de 2
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: étape 11, image 1 de 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: étape 11, image 2 de 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
9 autres ont terminé cette réparation.
Chayton Ritter
Membre depuis le 08/21/20
19 823 Réputation
105 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
8 membres
8 350 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 21
30 derniers jours : 114
Total : 2,680
