Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixelbook Battery (Back Panel) Replacement
Ce dont vous avez besoin
  1. Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): étape 1, image 1 de 3 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): étape 1, image 2 de 3 Google Pixelbook Battery (Back Panel) Replacement, Battery (Back Panel): étape 1, image 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixelbook Battery (Back Panel) Replacement: étape 2, image 1 de 2 Google Pixelbook Battery (Back Panel) Replacement: étape 2, image 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    Demander à FixBot
  3. Google Pixelbook Battery (Back Panel) Replacement: étape 3, image 1 de 3 Google Pixelbook Battery (Back Panel) Replacement: étape 3, image 2 de 3 Google Pixelbook Battery (Back Panel) Replacement: étape 3, image 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    Demander à FixBot
  4. Google Pixelbook Battery (Back Panel) Replacement: étape 4, image 1 de 3 Google Pixelbook Battery (Back Panel) Replacement: étape 4, image 2 de 3 Google Pixelbook Battery (Back Panel) Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    Demander à FixBot
  5. Google Pixelbook Battery (Back Panel) Replacement: étape 5, image 1 de 2 Google Pixelbook Battery (Back Panel) Replacement: étape 5, image 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    Demander à FixBot
  6. Google Pixelbook Battery (Back Panel) Replacement: étape 6, image 1 de 2 Google Pixelbook Battery (Back Panel) Replacement: étape 6, image 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
    Demander à FixBot
  7. Google Pixelbook Battery (Back Panel) Replacement: étape 7, image 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    Demander à FixBot
33 autres ont terminé cette réparation.
Megan Phillips
Membre depuis le 01/24/18
997 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 membres
9 tutoriels rédigés
25 commentaires de tutoriel
Question; with the rubber pads removed from the bottom…is there adhesive and if so, what’s best used to replace those and make it look factory stock again?
Fabian Aldo Santiago - Réponse Partager
The rubber pads are fixed with double sided tape.
Kornel Schwarcz - Réponse Partager
I just use Isopropyl alcohol to quickly and completely remove any adhesive residue and use an ample amount of JB Weld and Automotive Bondo to get the unit ready. Use a wet rag to remove any excess adhesive. Do not fo0rget to centrealize the Feline Eyelash right at the longest point of the night and invokie MARDUK!!! AAAHHRHRGH.
MyLil Hottie - Réponse Partager
So yeah basic Chemistry coupled with the ‘Dark Arts’ have created a sustainable situation.!
Where did you buy the back case replacement part?
cartercapelli - Réponse Partager
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 67
30 derniers jours : 336
Total : 42,836
