Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixelbook Touchpad Replacement
Ce dont vous avez besoin
  1. Google Pixelbook Touchpad Replacement, Battery (Back Panel): étape 1, image 1 de 3 Google Pixelbook Touchpad Replacement, Battery (Back Panel): étape 1, image 2 de 3 Google Pixelbook Touchpad Replacement, Battery (Back Panel): étape 1, image 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    Demander à FixBot
    Ajouter un commentaire
  2. Google Pixelbook Touchpad Replacement: étape 2, image 1 de 2 Google Pixelbook Touchpad Replacement: étape 2, image 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    Demander à FixBot
  3. Google Pixelbook Touchpad Replacement: étape 3, image 1 de 3 Google Pixelbook Touchpad Replacement: étape 3, image 2 de 3 Google Pixelbook Touchpad Replacement: étape 3, image 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    Demander à FixBot
  4. Google Pixelbook Touchpad Replacement: étape 4, image 1 de 3 Google Pixelbook Touchpad Replacement: étape 4, image 2 de 3 Google Pixelbook Touchpad Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    Demander à FixBot
  5. Google Pixelbook Touchpad Replacement: étape 5, image 1 de 2 Google Pixelbook Touchpad Replacement: étape 5, image 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    Demander à FixBot
  6. Google Pixelbook Touchpad Replacement: étape 6, image 1 de 2 Google Pixelbook Touchpad Replacement: étape 6, image 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
    Demander à FixBot
  7. Google Pixelbook Touchpad Replacement: étape 7, image 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    Demander à FixBot
  8. Google Pixelbook Touchpad Replacement, Touchpad: étape 8, image 1 de 3 Google Pixelbook Touchpad Replacement, Touchpad: étape 8, image 2 de 3 Google Pixelbook Touchpad Replacement, Touchpad: étape 8, image 3 de 3
    • Once the back panel is out of the way, use the T3 Torx screwdriver to turn both the 2.0mm and large 3.0mm gold screws from the touchpad.
    Demander à FixBot
  9. Google Pixelbook Touchpad Replacement: étape 9, image 1 de 3 Google Pixelbook Touchpad Replacement: étape 9, image 2 de 3 Google Pixelbook Touchpad Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up.
    Demander à FixBot
  10. Google Pixelbook Touchpad Replacement: étape 10, image 1 de 2 Google Pixelbook Touchpad Replacement: étape 10, image 2 de 2
    • Use the nylon spudger to push the touchpad out of the laptop by inserting the point into the hole near the edge of the laptop.
    • As the metal plates with the screws tilt upwards, use your hand to catch the falling touchpad and remove it.
    Demander à FixBot
3 autres ont terminé cette réparation.
Derrick Unger
Membre depuis le 01/24/18
361 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 membres
9 tutoriels rédigés
6 commentaires de tutoriel
Hello, I followed this guide and no the pixelbook will no longer power on. I reassembled exactly as described here. No light is coming on when I plu in the official charger, have tried other chargers as well. Any suggestions? I’ve been holding refresh + power and ESC but no change. Thanks…
saynotohotmail - Réponse Partager
lol $@$*…that’s reassuring ^^^ I was just about to order a replacement. Did you ever get it to turn back on? Or figure out what you did wrong lol?
Avh - Réponse Partager
What I read after the fact is that if you don’t do a full power off (hold refresh and power for 5 seconds until it is completely off) then the process here could short the motherboard. Which in my case it did. And I really wish these instructions had included something about that.
Ah I see! I just performed it last night actually, I did a regular shutdown via the “shutdown” button in the settings, everything went just fine luckily. Check out the corrosion that was causing my issue! http://imgur.com/gallery/cCfuGh2
In my settings under "devices" I didn't even have an option named “trackpad" - and that would be why,
Can anyone direct me to a source for a replacement touchpad? Thanks.
jacrider - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 11
30 derniers jours : 45
Total : 5,207
