Aller au contenu principal
Pour réparer ensemble - Je crée un compte
GravityLight LED Replacement
Ce dont vous avez besoin
    1. GravityLight LED Replacement, Removing the Front Panel: étape 1, image 1 de 2 GravityLight LED Replacement, Removing the Front Panel: étape 1, image 2 de 2
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
      Demander à FixBot
      Ajouter un commentaire
    2. GravityLight LED Replacement, Opening the Device Housing: étape 2, image 1 de 1
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
      Demander à FixBot
    1. GravityLight LED Replacement, Removing the Back Panel Screws: étape 3, image 1 de 1
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
      Demander à FixBot
    2. GravityLight LED Replacement, Removing the LED Housing: étape 4, image 1 de 2 GravityLight LED Replacement, Removing the LED Housing: étape 4, image 2 de 2
      • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
      • Lift the LED housing away from the back panel.
      Demander à FixBot
    3. GravityLight LED Replacement, Remove the White Gear from the LED Housing: étape 5, image 1 de 2 GravityLight LED Replacement, Remove the White Gear from the LED Housing: étape 5, image 2 de 2
      • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
      Demander à FixBot
    4. GravityLight LED Replacement, Position the LED Housing: étape 6, image 1 de 1
      • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
      Demander à FixBot
    5. GravityLight LED Replacement, Cut the Wires: étape 7, image 1 de 1
      • Place the GravityLight's back panel aside.
      • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
      Demander à FixBot
    6. GravityLight LED Replacement, Bend the LED Leads: étape 8, image 1 de 1
      Outil utilisé dans cette étape :
      • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
      • The straight leads will make the LED easier to take out.
      Demander à FixBot
    7. GravityLight LED Replacement, Remove the LED: étape 9, image 1 de 1
      • Flip the LED housing over.
      • Pull the LED out with tweezers.
      Demander à FixBot
    8. GravityLight LED Replacement, Soldering the New LED: étape 10, image 1 de 1
      • For reassembly: Flip the LED housing back over.
      • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
      • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
      • For information on how to solder look here: Comment souder et dessouder des connexions
      Demander à FixBot
Brian Gouldsberry
Membre depuis le 09/26/14
201 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-2, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 membres
84 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 96
Total : 1,148
