Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HMD Barbie Keypad Replacement
Ce dont vous avez besoin
  1. HMD Barbie Keypad Replacement, Battery: étape 1, image 1 de 3 HMD Barbie Keypad Replacement, Battery: étape 1, image 2 de 3 HMD Barbie Keypad Replacement, Battery: étape 1, image 3 de 3
    • Fully power off the phone.
    • Remove the backplate by gripping it around the edges and pulling away from the phone.
    Demander à FixBot
    Ajouter un commentaire
  2. HMD Barbie Keypad Replacement: étape 2, image 1 de 3 HMD Barbie Keypad Replacement: étape 2, image 2 de 3 HMD Barbie Keypad Replacement: étape 2, image 3 de 3
    • Grip the battery from the top and pull away from the phone.
    • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
    Demander à FixBot
  3. HMD Barbie Keypad Replacement, Inner Backplate: étape 3, image 1 de 1
    • Remove the six 5mm screws using the T5 Torx screwdriver.
    Demander à FixBot
  4. HMD Barbie Keypad Replacement: étape 4, image 1 de 2 HMD Barbie Keypad Replacement: étape 4, image 2 de 2
    • Remove the backplate using an opening tool.
    • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
    Demander à FixBot
  5. HMD Barbie Keypad Replacement, Motherboard: étape 5, image 1 de 3 HMD Barbie Keypad Replacement, Motherboard: étape 5, image 2 de 3 HMD Barbie Keypad Replacement, Motherboard: étape 5, image 3 de 3
    • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
    Demander à FixBot
  6. HMD Barbie Keypad Replacement: étape 6, image 1 de 3 HMD Barbie Keypad Replacement: étape 6, image 2 de 3 HMD Barbie Keypad Replacement: étape 6, image 3 de 3
    • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
    • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
    • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
    • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
    Demander à FixBot
  7. HMD Barbie Keypad Replacement: étape 7, image 1 de 3 HMD Barbie Keypad Replacement: étape 7, image 2 de 3 HMD Barbie Keypad Replacement: étape 7, image 3 de 3
    • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
    • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
    Demander à FixBot
  8. HMD Barbie Keypad Replacement, Keypad: étape 8, image 1 de 3 HMD Barbie Keypad Replacement, Keypad: étape 8, image 2 de 3 HMD Barbie Keypad Replacement, Keypad: étape 8, image 3 de 3
    • Push the keypad out of the outer casing from the front of the phone, outward.
    • You may now replace the keypad with a new one, inserting it where the old keypad was. Make sure to not obstruct any of the holes for screws with the keypad.
    Demander à FixBot
Hannah Carvalho
Membre depuis le 03/09/26
571 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-2, Botvin Spring 2026 Membre de l'équipe UMass Dartmouth, Team 6-2, Botvin Spring 2026
UMASSD-BOTVIN-S26S6G2
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 31
Total : 90
