Introduction
Follow this guide to replace a dead or worn-out battery in your HMD Pulse smartphone.
Your phone's lithium-ion battery has a limited lifespan. If your phone dies quickly and doesn't hold a charge, it may be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
Outil utilisé dans cette étape :Tweezers$4.99
Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
Use your fingers to carefully peel the three plastic tabs from the left side of the battery.
Remove the battery and its film.
If the adhesive in the battery recess is still sticky, you don't need to replace it.
If the adhesive isn't sticky, use a spudger and tweezers to peel up and remove the two pieces of battery adhesive. Then, apply the new adhesive to the frame and remove the plastic liners.
Firmly press the battery into its recess so the cable is on the top edge and the three tabs are on the left edge.
For optimal performance, calibrate your newly installed battery after reassembling your phone.
