Introduction
Follow this guide to replace a cracked or damaged back cover on your HMD Pulse Pro smartphone.
Ce dont vous avez besoin
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
Outil utilisé dans cette étape :Tweezers$4.99
Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
Use a pair of tweezers to gently grip the power button's top rubber arm and lift it out of its slot.
