Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HMDX Jam Battery Replacement
Ce dont vous avez besoin
  1. HMDX Jam Battery Replacement, Opening speaker: étape 1, image 1 de 1
    • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
    Demander à FixBot
    Ajouter un commentaire
  2. HMDX Jam Battery Replacement, remove rubber cover: étape 2, image 1 de 1
    • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
    Demander à FixBot
  3. HMDX Jam Battery Replacement, Remove screws: étape 3, image 1 de 1
    • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
    • It would be wise to use a magnetic mat for the screws for safekeeping.
    Demander à FixBot
  4. HMDX Jam Battery Replacement, Exposing Battery: étape 4, image 1 de 1
    • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
    Demander à FixBot
  5. HMDX Jam Battery Replacement, Removing Battery: étape 5, image 1 de 1
    • Very gently remove the battery from the motherboard.
    Demander à FixBot
  6. HMDX Jam Battery Replacement, Remove battery attachments: étape 6, image 1 de 2 HMDX Jam Battery Replacement, Remove battery attachments: étape 6, image 2 de 2
    • Use a solder gun to remove the battery attachments from the motherboard.
    Demander à FixBot
42 autres ont terminé cette réparation.
Équipe
USF Tampa, Team 1-1, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 membres
4 tutoriels rédigés
18 commentaires de tutoriel
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Réponse Partager
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Réponse Partager
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Réponse Partager
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Réponse Partager
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 113
Total : 98,722
