Aller au contenu principal
HP 14-cf2112wm Battery Replacement
Ce dont vous avez besoin
  1. HP 14-cf2112wm Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Before you begin, shut down your laptop and disconnect all cables.
    • Turn the laptop over so the bottom case is facing up.
  2. HP 14-cf2112wm Battery Replacement: étape 2, image 1 de 2 HP 14-cf2112wm Battery Replacement: étape 2, image 2 de 2
    • Use a spudger to pry under the end of the screw cover.
    • When the edge is lifted up, use your fingers to pull the rest of the strip off.
    • Try to keep the strip intact so you can replace it at reassembly.
  3. HP 14-cf2112wm Battery Replacement: étape 3, image 1 de 2 HP 14-cf2112wm Battery Replacement: étape 3, image 2 de 2
    • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
  4. HP 14-cf2112wm Battery Replacement: étape 4, image 1 de 3 HP 14-cf2112wm Battery Replacement: étape 4, image 2 de 3 HP 14-cf2112wm Battery Replacement: étape 4, image 3 de 3
    • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
    • Be careful as the case edges are sharp.
  5. HP 14-cf2112wm Battery Replacement: étape 5, image 1 de 1
    • Lift the back cover off the laptop.
  6. HP 14-cf2112wm Battery Replacement, Battery: étape 6, image 1 de 3 HP 14-cf2112wm Battery Replacement, Battery: étape 6, image 2 de 3 HP 14-cf2112wm Battery Replacement, Battery: étape 6, image 3 de 3
    • Place your opened laptop on a flat surface.
    • Use a Phillips #1 screwdriver to remove the four Phillips 3.0 mm screws securing the battery.
  7. HP 14-cf2112wm Battery Replacement: étape 7, image 1 de 2 HP 14-cf2112wm Battery Replacement: étape 7, image 2 de 2
    • Slide the battery out from the connector on the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Shishi Hu
Membre depuis le 03/18/24
763 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Konn Spring 2024 Membre de l'équipe UMass Dartmouth, Team 1-2, Konn Spring 2024
UMASSD-KONN-S24S1G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 15
Total : 77
