Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP 15-R263DX RAM Replacement
Ce dont vous avez besoin
  1. HP 15-R263DX RAM Replacement, Battery: étape 1, image 1 de 2 HP 15-R263DX RAM Replacement, Battery: étape 1, image 2 de 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Demander à FixBot
    Ajouter un commentaire
  2. HP 15-R263DX RAM Replacement, Optical Drive: étape 2, image 1 de 2 HP 15-R263DX RAM Replacement, Optical Drive: étape 2, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    Demander à FixBot
  3. HP 15-R263DX RAM Replacement: étape 3, image 1 de 1
    • Gently slide the optical drive out of the side of the computer.
    Demander à FixBot
  4. HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: étape 4, image 1 de 2 HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: étape 4, image 2 de 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    Demander à FixBot
  5. HP 15-R263DX RAM Replacement: étape 5, image 1 de 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    Demander à FixBot
  6. HP 15-R263DX RAM Replacement: étape 6, image 1 de 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    Demander à FixBot
  7. HP 15-R263DX RAM Replacement: étape 7, image 1 de 2 HP 15-R263DX RAM Replacement: étape 7, image 2 de 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Demander à FixBot
  8. HP 15-R263DX RAM Replacement: étape 8, image 1 de 2 HP 15-R263DX RAM Replacement: étape 8, image 2 de 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    Demander à FixBot
  9. HP 15-R263DX RAM Replacement: étape 9, image 1 de 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    Demander à FixBot
  10. HP 15-R263DX RAM Replacement, Hard Drive: étape 10, image 1 de 1
    • Remove the 2 black screws holding the hard drive to the computer frame.
    Demander à FixBot
  11. HP 15-R263DX RAM Replacement: étape 11, image 1 de 2 HP 15-R263DX RAM Replacement: étape 11, image 2 de 2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
    Demander à FixBot
  12. HP 15-R263DX RAM Replacement, RAM: étape 12, image 1 de 1
    • Remove the 2 screws holding the motherboard into the case of the laptop.
    Demander à FixBot
  13. HP 15-R263DX RAM Replacement: étape 13, image 1 de 2 HP 15-R263DX RAM Replacement: étape 13, image 2 de 2
    • Remove the connections around the motherboard.
    • There is a connection hidden underneath the board. Remove this one last as you will need to lift the motherboard up to access it.
    Demander à FixBot
  14. HP 15-R263DX RAM Replacement: étape 14, image 1 de 2 HP 15-R263DX RAM Replacement: étape 14, image 2 de 2
    • Remove the screw holding the WiFi chip in place.
    • Slide the chip away from the motherboard and set it elsewhere inside the computer.
    Demander à FixBot
  15. HP 15-R263DX RAM Replacement: étape 15, image 1 de 1
    • Flip the motherboard over to access the underside revealing the RAM.
    Demander à FixBot
  16. HP 15-R263DX RAM Replacement: étape 16, image 1 de 2 HP 15-R263DX RAM Replacement: étape 16, image 2 de 2
    • Remove the RAM chip by simultaneously prying the 2 spring clips away from the RAM.
    • The RAM will pop up when both clips are completely released.
    Demander à FixBot
5 autres ont terminé cette réparation.
Drake Hort
Membre depuis le 03/05/18
487 Réputation
3 tutoriels rédigés
Équipe
Washington State, Team S2-G3, Lobnitz Spring 2018 Membre de l'équipe Washington State, Team S2-G3, Lobnitz Spring 2018
WSU-LOBNITZ-S18S2G3
8 membres
7 tutoriels rédigés
1 commentaire de tutoriel
is this laptop model ram upgradable?
Gordon Velupillai - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 34
Total : 1,905
