Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP 2000 - 2D22DX RAM Replacement
Ce dont vous avez besoin
  1. HP 2000 - 2D22DX RAM Replacement, Battery: étape 1, image 1 de 2 HP 2000 - 2D22DX RAM Replacement, Battery: étape 1, image 2 de 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
    Demander à FixBot
    Ajouter un commentaire
  2. HP 2000 - 2D22DX RAM Replacement: étape 2, image 1 de 2 HP 2000 - 2D22DX RAM Replacement: étape 2, image 2 de 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    Demander à FixBot
  3. HP 2000 - 2D22DX RAM Replacement, RAM: étape 3, image 1 de 2 HP 2000 - 2D22DX RAM Replacement, RAM: étape 3, image 2 de 2
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    Demander à FixBot
  4. HP 2000 - 2D22DX RAM Replacement: étape 4, image 1 de 2 HP 2000 - 2D22DX RAM Replacement: étape 4, image 2 de 2
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
    Demander à FixBot
  5. HP 2000 - 2D22DX RAM Replacement: étape 5, image 1 de 3 HP 2000 - 2D22DX RAM Replacement: étape 5, image 2 de 3 HP 2000 - 2D22DX RAM Replacement: étape 5, image 3 de 3
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
    Demander à FixBot
  6. HP 2000 - 2D22DX RAM Replacement: étape 6, image 1 de 1
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
    Demander à FixBot
7 autres ont terminé cette réparation.
Conor Most
Membre depuis le 04/14/14
2 778 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-40, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 61
Total : 4,338
