Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Chromebook 14-Q010DX Battery Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: étape 1, image 1 de 2 HP Chromebook 14-Q010DX Battery Replacement, Keyboard and Touchpad: étape 1, image 2 de 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Chromebook 14-Q010DX Battery Replacement: étape 2, image 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 2, image 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 2, image 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Demander à FixBot
  3. HP Chromebook 14-Q010DX Battery Replacement: étape 3, image 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 3, image 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 3, image 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Demander à FixBot
  4. HP Chromebook 14-Q010DX Battery Replacement: étape 4, image 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Demander à FixBot
  5. HP Chromebook 14-Q010DX Battery Replacement: étape 5, image 1 de 1
    • Set aside the detached keyboard.
    Demander à FixBot
  6. HP Chromebook 14-Q010DX Battery Replacement, Speaker: étape 6, image 1 de 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: étape 6, image 2 de 3 HP Chromebook 14-Q010DX Battery Replacement, Speaker: étape 6, image 3 de 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Demander à FixBot
  7. HP Chromebook 14-Q010DX Battery Replacement: étape 7, image 1 de 2 HP Chromebook 14-Q010DX Battery Replacement: étape 7, image 2 de 2
    • Gently remove the speakers.
    Demander à FixBot
  8. HP Chromebook 14-Q010DX Battery Replacement, Battery: étape 8, image 1 de 2 HP Chromebook 14-Q010DX Battery Replacement, Battery: étape 8, image 2 de 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Demander à FixBot
  9. HP Chromebook 14-Q010DX Battery Replacement: étape 9, image 1 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 9, image 2 de 3 HP Chromebook 14-Q010DX Battery Replacement: étape 9, image 3 de 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Demander à FixBot
  10. HP Chromebook 14-Q010DX Battery Replacement: étape 10, image 1 de 1
    • Gently remove battery.
    Demander à FixBot
6 autres ont terminé cette réparation.
Kevin Piper
Membre depuis le 01/16/15
1 602 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 membres
8 tutoriels rédigés
3 commentaires de tutoriel
Nice guide, guys!
dergrossmeister50 - Réponse Partager
Thanks, hope it made life a bit easier for you!
Kevin Piper - Réponse Partager
Very clear and concise. Nice going! Thank you.
sparkydog1725 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 35
Total : 14,316
