Aller au contenu principal
HP Chromebook 14-ak041dx Heat Sink Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ak041dx Heat Sink Replacement, Keyboard: étape 1, image 1 de 2 HP Chromebook 14-ak041dx Heat Sink Replacement, Keyboard: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Heat Sink Replacement: étape 2, image 1 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 2, image 2 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 2, image 3 de 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Heat Sink Replacement: étape 3, image 1 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 3, image 2 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 3, image 3 de 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Heat Sink Replacement, Battery: étape 4, image 1 de 2 HP Chromebook 14-ak041dx Heat Sink Replacement, Battery: étape 4, image 2 de 2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Heat Sink Replacement: étape 5, image 1 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 5, image 2 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement: étape 5, image 3 de 3
    J'achète
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Heat Sink Replacement: étape 6, image 1 de 1
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: étape 7, image 1 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: étape 7, image 2 de 3 HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: étape 7, image 3 de 3
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
Kristen Gismondi
Membre depuis le 11/12/14
82 296 Réputation
200 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 299 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 157
