Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Compaq 515 Wireless Card Replacement
Ce dont vous avez besoin
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Compaq 515 Wireless Card Replacement: étape 2, image 1 de 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
    Demander à FixBot
  3. HP Compaq 515 Wireless Card Replacement: étape 3, image 1 de 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    Demander à FixBot
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: étape 4, image 1 de 1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
    Demander à FixBot
  5. HP Compaq 515 Wireless Card Replacement: étape 5, image 1 de 1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
    Demander à FixBot
  6. HP Compaq 515 Wireless Card Replacement: étape 6, image 1 de 2 HP Compaq 515 Wireless Card Replacement: étape 6, image 2 de 2
    • Slide the wireless card backing towards you to remove it from the laptop.
    Demander à FixBot
  7. HP Compaq 515 Wireless Card Replacement: étape 7, image 1 de 1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
    Demander à FixBot
  8. HP Compaq 515 Wireless Card Replacement: étape 8, image 1 de 1
    • Remove the two .4 cm screws with a PH00 bit.
    Demander à FixBot
Aleks B
Membre depuis le 03/19/18
337 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G1, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G1, Covino Spring 2018
UMASSD-COVINO-S18S4G1
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 541
