Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Compaq 6710b Keyboard Replacement
Ce dont vous avez besoin
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: étape 1, image 1 de 3 HP Compaq 6710b Keyboard Replacement, Keyboard: étape 1, image 2 de 3 HP Compaq 6710b Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Compaq 6710b Keyboard Replacement: étape 2, image 1 de 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    Demander à FixBot
  3. HP Compaq 6710b Keyboard Replacement: étape 3, image 1 de 2 HP Compaq 6710b Keyboard Replacement: étape 3, image 2 de 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    Demander à FixBot
  4. HP Compaq 6710b Keyboard Replacement: étape 4, image 1 de 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    Demander à FixBot
4 autres ont terminé cette réparation.
Khulan Orgil
Membre depuis le 04/14/15
1 186 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 4-2, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 membres
6 tutoriels rédigés
2 commentaires de tutoriel
No parts required to *replace* the keyboard?
David - Réponse Partager
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 50
Total : 5,679
