Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Compaq nc6400 Bluetooth Module Replacement
Ce dont vous avez besoin
  1. HP Compaq nc6400 Bluetooth Module Replacement, Battery: étape 1, image 1 de 1
    • Turn off and unplug laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Compaq nc6400 Bluetooth Module Replacement: étape 2, image 1 de 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    Demander à FixBot
  3. HP Compaq nc6400 Bluetooth Module Replacement: étape 3, image 1 de 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    Demander à FixBot
  4. HP Compaq nc6400 Bluetooth Module Replacement: étape 4, image 1 de 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
    Demander à FixBot
  5. HP Compaq nc6400 Bluetooth Module Replacement, Bluetooth Module: étape 5, image 1 de 1
    • Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
    • Remove the screw.
    Demander à FixBot
  6. HP Compaq nc6400 Bluetooth Module Replacement: étape 6, image 1 de 3 HP Compaq nc6400 Bluetooth Module Replacement: étape 6, image 2 de 3 HP Compaq nc6400 Bluetooth Module Replacement: étape 6, image 3 de 3
    • Lift the right side of the Bluetooth Module cover upwards.
    • Slide the spudger under the lifted case, and slide it left towards the closed end. The case will pop open and be removed from the compartment.
    Demander à FixBot
  7. HP Compaq nc6400 Bluetooth Module Replacement: étape 7, image 1 de 1
    • Locate the Bluetooth Module after removing the cover.
    • Using the spudger, push the module to the right (i.e. towards the screw hole).
    • Pull outwards and remove bluetooth module and wire from casing.
    Demander à FixBot
  8. HP Compaq nc6400 Bluetooth Module Replacement: étape 8, image 1 de 2 HP Compaq nc6400 Bluetooth Module Replacement: étape 8, image 2 de 2
    • Once the module and wire are completely outside of the casing, gently pull apart the wire from the module clip.
    Demander à FixBot
3 autres ont terminé cette réparation.
Yoshitake Yamada
Membre depuis le 09/30/13
266 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-6, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
Alain Bastien - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 36
Total : 2,633
