Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: étape 1, image 1 de 2 HP Flyer Red Battery Replacement, Battery: étape 1, image 2 de 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Flyer Red Battery Replacement: étape 2, image 1 de 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    Demander à FixBot
  3. HP Flyer Red Battery Replacement: étape 3, image 1 de 2 HP Flyer Red Battery Replacement: étape 3, image 2 de 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    Demander à FixBot
  4. HP Flyer Red Battery Replacement: étape 4, image 1 de 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    Demander à FixBot
7 autres ont terminé cette réparation.
Anthony Ciotti
Membre depuis le 04/07/16
777 Réputation
5 tutoriels rédigés
1 commentaire de tutoriel
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 7
30 derniers jours : 34
Total : 2,721
