Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Flyer Red Keyboard Replacement
Ce dont vous avez besoin
  1. HP Flyer Red Keyboard Replacement, Battery: étape 1, image 1 de 2 HP Flyer Red Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Flyer Red Keyboard Replacement: étape 2, image 1 de 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    Demander à FixBot
  3. HP Flyer Red Keyboard Replacement: étape 3, image 1 de 2 HP Flyer Red Keyboard Replacement: étape 3, image 2 de 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    Demander à FixBot
  4. HP Flyer Red Keyboard Replacement: étape 4, image 1 de 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    Demander à FixBot
  5. HP Flyer Red Keyboard Replacement, Keyboard: étape 5, image 1 de 2 HP Flyer Red Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
    Demander à FixBot
  6. HP Flyer Red Keyboard Replacement: étape 6, image 1 de 3 HP Flyer Red Keyboard Replacement: étape 6, image 2 de 3 HP Flyer Red Keyboard Replacement: étape 6, image 3 de 3
    • Next turn the laptop over and flip open the screen.
    • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
    • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
    Demander à FixBot
  7. HP Flyer Red Keyboard Replacement: étape 7, image 1 de 3 HP Flyer Red Keyboard Replacement: étape 7, image 2 de 3 HP Flyer Red Keyboard Replacement: étape 7, image 3 de 3
    • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
    • Gently slide the ribbon wire out of its slot.
    Demander à FixBot
7 autres ont terminé cette réparation.
Anthony Ciotti
Membre depuis le 04/07/16
777 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 35
Total : 2,603
