Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ProBook 4320t Keyboard Replacement Guide
Ce dont vous avez besoin
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: étape 1, image 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: étape 1, image 2 de 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Demander à FixBot
    Ajouter un commentaire
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: étape 2, image 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Screws: étape 2, image 2 de 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Demander à FixBot
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: étape 3, image 1 de 1
    • Flip laptop over and open it.
    Demander à FixBot
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: étape 4, image 1 de 1
    • Slightly push up while lifting up on the power button panel to release the panel.
    Demander à FixBot
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: étape 5, image 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Demander à FixBot
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: étape 6, image 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: étape 6, image 2 de 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Demander à FixBot
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: étape 7, image 1 de 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Demander à FixBot
Joshua
Membre depuis le 09/23/14
134 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 23
Total : 1,245
