Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP ProBook 4520s Keyboard Replacement
Ce dont vous avez besoin
  1. HP ProBook 4520s Keyboard Replacement, Battery: étape 1, image 1 de 2 HP ProBook 4520s Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    Demander à FixBot
    Ajouter un commentaire
  2. HP ProBook 4520s Keyboard Replacement: étape 2, image 1 de 1
    • Remove the battery by holding the latches and sliding the battery away from you.
    Demander à FixBot
  3. HP ProBook 4520s Keyboard Replacement, Switch Cover: étape 3, image 1 de 2 HP ProBook 4520s Keyboard Replacement, Switch Cover: étape 3, image 2 de 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    Demander à FixBot
  4. HP ProBook 4520s Keyboard Replacement: étape 4, image 1 de 2 HP ProBook 4520s Keyboard Replacement: étape 4, image 2 de 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    Demander à FixBot
  5. HP ProBook 4520s Keyboard Replacement: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    Demander à FixBot
  6. HP ProBook 4520s Keyboard Replacement: étape 6, image 1 de 3 HP ProBook 4520s Keyboard Replacement: étape 6, image 2 de 3 HP ProBook 4520s Keyboard Replacement: étape 6, image 3 de 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    Demander à FixBot
  7. HP ProBook 4520s Keyboard Replacement, Keyboard: étape 7, image 1 de 2 HP ProBook 4520s Keyboard Replacement, Keyboard: étape 7, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
    Demander à FixBot
  8. HP ProBook 4520s Keyboard Replacement: étape 8, image 1 de 1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
    Demander à FixBot
  9. HP ProBook 4520s Keyboard Replacement: étape 9, image 1 de 2 HP ProBook 4520s Keyboard Replacement: étape 9, image 2 de 2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
    Demander à FixBot
To reassemble your device, follow these steps in reverse order.
7 autres ont terminé cette réparation.
Robert Spencer Harrison
Membre depuis le 09/21/16
1 422 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team 1-3, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 membres
8 tutoriels rédigés
1 commentaire de tutoriel
hp probook 4520s disassembly
https://youtu.be/8749zmz0lls
mohamed - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 42
Total : 5,286
