Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Droid DNA Micro USB Port Replacement
Ce dont vous avez besoin
  1. HTC Droid DNA Micro USB Port Replacement, Remove the SIM Card Tray: étape 1, image 1 de 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    Demander à FixBot
    Ajouter un commentaire
  2. HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: étape 2, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: étape 2, image 2 de 2
    • Pull out the SIM Card Tray with your fingers.
    Demander à FixBot
  3. HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: étape 3, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: étape 3, image 2 de 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
    Demander à FixBot
  4. HTC Droid DNA Micro USB Port Replacement, Pull the Casing Apart: étape 4, image 1 de 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
    Demander à FixBot
  5. HTC Droid DNA Micro USB Port Replacement, Remove the Black Tape: étape 5, image 1 de 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    Demander à FixBot
  6. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    Demander à FixBot
  7. HTC Droid DNA Micro USB Port Replacement: étape 7, image 1 de 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    Demander à FixBot
  8. HTC Droid DNA Micro USB Port Replacement, Remove the Void Screw: étape 8, image 1 de 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    Demander à FixBot
  9. HTC Droid DNA Micro USB Port Replacement, Remove the Screw Retaining Bracket: étape 9, image 1 de 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    Demander à FixBot
  10. HTC Droid DNA Micro USB Port Replacement, Remove the Connector Screws: étape 10, image 1 de 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
    Demander à FixBot
  11. HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: étape 11, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: étape 11, image 2 de 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    Demander à FixBot
  12. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: étape 12, image 1 de 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
    Demander à FixBot
  13. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 13, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 13, image 2 de 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    Demander à FixBot
  14. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: étape 14, image 1 de 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
    Demander à FixBot
  15. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 15, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 15, image 2 de 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    Demander à FixBot
  16. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: étape 16, image 1 de 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
    Demander à FixBot
  17. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 17, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: étape 17, image 2 de 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    Demander à FixBot
  18. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: étape 18, image 1 de 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
    Demander à FixBot
  19. HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: étape 19, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: étape 19, image 2 de 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    Demander à FixBot
  20. HTC Droid DNA Micro USB Port Replacement, Disconnect the Small Ribbon Connector: étape 20, image 1 de 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    Demander à FixBot
  21. HTC Droid DNA Micro USB Port Replacement, Remove the Black Wire: étape 21, image 1 de 1
    • Remove the long black wire on the left of the motherboard.
    Demander à FixBot
  22. HTC Droid DNA Micro USB Port Replacement, Remove the Two Black Wires: étape 22, image 1 de 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    Demander à FixBot
  23. HTC Droid DNA Micro USB Port Replacement, Remove the Screws: étape 23, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    Demander à FixBot
  24. HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: étape 24, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: étape 24, image 2 de 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    Demander à FixBot
  25. HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: étape 25, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: étape 25, image 2 de 2
    • Use the plastic prying tool to gently remove the charging port assembly.
    Demander à FixBot
  26. HTC Droid DNA Micro USB Port Replacement, Disassemble Charging Port Assembly: étape 26, image 1 de 1
    • Use a Phillips #000 screw driver to remove the single 2.1mm screw located on the backside of the assembly.
    Demander à FixBot
  27. HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: étape 27, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: étape 27, image 2 de 2
    • Use your tweezers to undo the red and black wire connection.
    Demander à FixBot
  28. HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: étape 28, image 1 de 3 HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: étape 28, image 2 de 3 HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: étape 28, image 3 de 3
    • Use the plastic prying tool to separate the assembly into two pieces: blue and black.
    Demander à FixBot
  29. HTC Droid DNA Micro USB Port Replacement, Remove the wire: étape 29, image 1 de 2 HTC Droid DNA Micro USB Port Replacement, Remove the wire: étape 29, image 2 de 2
    • Remove the black wire on the blue piece (the Micro USB charging port) so it is out of the way and cannot get damaged.
    • If the micro USB port is damaged, the charging port may need to be replaced.
    Demander à FixBot
Madeline Tran
Membre depuis le 10/14/14
707 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-43, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 42
Total : 2,770
